Automatic ups circuit diagram
Discussion in 'General Electronics Chat' started by fayazahmedmemon, Jan 14, 2011.
  1. fayazahmedmemon
    Jul 4, 2010
    15
    I have made a 500 watt ups and it is working manually.i want to make the ups circuit fully automatic so that if wall outlet power goes off then it sarts to work and gives power and when wall outlet power comes back then it stops its working and begins to charge the battery.i am sending a schematic diagram so plz tell me how can i make it fully automatic with the use of relay or an other devicexplz send me the circuit diagram required.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    That's not a schematic, it's only a very simple block diagram.
  3. R!f@@
    Apr 2, 2009
    8,792
    771
    No Bill, can't u see he had build it.
  4. thatoneguy
    Feb 19, 2009
    6,357
    718
    If that is the way it is wired, there are some problems.
    You are using power out of the inverter (assuming the battery exists still), which means you are wasting at least 20% of the power from the outlet due to the step-down and step-up process. It's a waste of electricity. For every 100W-H you use, you will be paying for 120W-H or 140W-H.
    APC makes nice online UPS systems that switch within a millisecond and are rated for 20000VA and above. They cost around $5,000 for the higher rated, but 14000VA is only $90US.
  5. BillB3857
    Feb 28, 2009
    2,402
    348
    WHERE? I'll take one!
  6. tom66
    May 9, 2009
    2,613
    214
    It's important not to worry too much about switching time, as a modern computer power supply typically has a hold-up time (the time for which it can operate without input mains) of around 16 ms to 40 ms, at full load.
  7. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Why don't you start by posting the actual schematic for the inverter (rather than the functional diagram) and we'll progress from there?
    Basically, you'll need a relay that is 3PDT; or three-pole double-throw. You really don't need the inverter running when the AC is on. However, when the AC fails, you need a relay to disconnect both poles of the AC input, along with providing DC to the inverter - and transferring the load to the inverter output.
