automatic poweroff circuit.
Discussion in 'The Projects Forum' started by Mhine28, Sep 8, 2014.
  1. Mhine28
    Sep 2, 2014
    10
    hi people...
    im just going to ask if is there some king of circuit that can cut a power line from a outlet?
    and can you tell me guys how?
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    the simplest type is known as a circuit breaker. more info needed to give a morr specific answer. sensing current flow and operating a relay would be another.
  3. ErnieM
    Apr 24, 2011
    7,439
    1,627
    A switch works wonders, but you have to stand by to opperate it when necessary.
    Perhaps you should share some other facts about your needs.
  4. crutschow
    Mar 14, 2008
    13,505
    3,376
    Under what conditions do you want the power cut from the outlet?
  5. wayneh
    Sep 9, 2010
    12,391
    3,246
    Lamp timer?
  6. Mhine28
    Sep 2, 2014
    10
    it is suppose to cut automatically by timer...
  7. #12
    Nov 30, 2010
    16,704
    7,354
  8. Mhine28
    Sep 2, 2014
    10
    i know there is already a device for that...
    im asking if how does it cut it off?
    and im not talking about analog type...'
    im thinking about the digital version...
  9. Kermit2
    Feb 5, 2010
    3,852
    968
    a timer cuts off power with a switch. some are mechanical and just open a set of contacts. others use a control voltage to operate a solid state relay.
  10. #12
    Nov 30, 2010
    16,704
    7,354
    The ones I design usually fire a triac...or not, and "not" means, "off".
