automatic lighting
Discussion in 'General Electronics Chat' started by SaraSa, Feb 12, 2009.
  1. SaraSa
    Feb 11, 2009
    25
    I'm searching for a simple circuit of automatic lighting that includes triac. Can anyone show me the circuit?
  2. mik3
    Feb 4, 2008
    4,846
    63
    From where the light will be activated automatically?
  3. SaraSa
    Feb 11, 2009
    25
    My circuit should be activated by a battery(6v), and it includes relay too.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Unless the lighting includes a dimming feature, the relay should provide adequate control for on/off. Triacs don't work with DC, either for control or for on/off operation.
    We need more information about the circuit you have in mind.
  5. mik3
    Feb 4, 2008
    4,846
    63
    Yes but what will cause the relay to turn on?
    I mean on what condition the light will light?
  6. SaraSa
    Feb 11, 2009
    25
    When the weather is dark, the triac causes to turn on the light. What should I do to use triac instead of relay and there is a battery(6v) to provide current of the light(220v). Also, turn off it when the weather is light.
  7. SaraSa
    Feb 11, 2009
    25
    Alberto,
    Thanks for your suggestion, but you're missing the point. My aim is to learn how to design a simple circuit.
  8. SaraSa
    Feb 11, 2009
    25
    another suggestion?
  9. mik3
    Feb 4, 2008
    4,846
    63
    Is the lamp a 120VAC or 240VAC one?
  10. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
  11. SaraSa
    Feb 11, 2009
    25
    I think yes. Isn't the streets or homes' lamps 230VAC?
  12. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Depends where you live.
    Here in Holland (and most countries in europe) it is 230 Volts.
    In the USA it is 120 Volts.
    Greetings,
    Bertus
  13. SaraSa
    Feb 11, 2009
    25
  14. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
