Automatic Heat Detector
Discussion in 'The Projects Forum' started by yuanshikai, Mar 8, 2012.
  1. yuanshikai
    Sep 17, 2011
    49
    Hello all. I saw this circuit for an automatic heat detector.
    http://3.bp.blogspot.com/-q6eVYCfqB...is6Xo0DFjo/s1600/Automatic+Heat+Detectorw.gif
    But i want to replace the relay controlling mechanism with a PIC16F84 microcontroller. So how does T1 and T2 really work? Do they allow current to pass through when there is heat? Do they really have to be configured like that? Can't i use more common transistors?
    And for the amplifier T3-T4. Can i also replace them with more common transistors like bc547 or 2n2222?
    Also, what's the purpose of the 3V zener?
    The description is here http://www.extremecircuits.net/2011/08/automatic-heat-detector.html
  2. PaulEE
    Member
    Dec 23, 2011
    423
    32
    The circuit works off the premise that a temperature rise in the transistor whose base is left disconnected causes sufficient current to flow through the drive transistor for the relay...turning the relay on. The rest of the circuit is a voltage regulator and buzzer. It can be anything you want.
    I would define your problem (EXACTLY what you want to accomplish) and then post it. The forum, collectively, can then give you input on the best way to go about solving your problem... :)
  3. yuanshikai
    Sep 17, 2011
    49
    Could I replace the transistors with ones more common in our area like 2n2222 and bc547?
