automatic doorbell
Discussion in 'General Electronics Chat' started by rijoe.mathew, Sep 21, 2014.
  1. rijoe.mathew
    Sep 21, 2014
    42
    i have this circuit for my project.can i replace the 7555 with ne 555.what are the changes needed.please reply fast.
    anyone please reply fast.i need this for tomorrow
  2. crutschow
    Mar 14, 2008
    13,530
    3,393
    The 7555 is a CMOS version of the original 555 which uses BJT transistors. It should work in your circuit.
    Note that there appears to be an error in that circuit. I think there should be a dot where the pin 6 connection crosses the pin 2 connection to indicated they should be connected together. Also, that circuit is not the typical astable multivibrator circuit for a 555 as seen here.
    rijoe.mathew likes this.
  3. ericgibbs
    Jan 29, 2010
    2,606
    396
  4. rijoe.mathew
    Sep 21, 2014
    42
    [​IMG] now i replaced the original circuit 7555 with this circuit where R1=600 ohms,R2=18 kilo ohms, and C=.001uF.Is there any problem with the connections of LM324.Please advise how to identify the emitter of BC337 and BC327.its seems like the two transistor are heating up when i connect the input.please advice.is the any polarity for ultrasonic transducers
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,464
    792
    You may find lower resistances are needed around the timing pins.
    An undesirable feature of the bipolar 555, is the crossover point on the output stage - it has a tiny blip of crowbarring Vcc as one transistor hands over to the other, this can glitch other parts of the circuit.
    You should put a 100nF cap as close as possible to the 555 supply pins, you should also have some bulk reservoir/bypass of at least 100uF for the whole circuit.
  6. ericgibbs
    Jan 29, 2010
    2,606
    396
    hi rijoe,
    You cannot use that version of a 555 astable to drive an ultrasonic transducer.
    It requires a 50:50 drive signal, at the same frequency as the original design. You will 'cook' the drive transistors!
    Why have you changed the 555 circuit,?
    Eric
  7. rijoe.mathew
    Sep 21, 2014
    42
    when i used the circuit given in the diagram.it didnt work.i was not getting a 40khz signal at the output when i connected it to a CRO
  8. rijoe.mathew
    Sep 21, 2014
    42
    Is there any mistakes in amplifier part.it seems like some dots(connections) are missing
  9. ericgibbs
    Jan 29, 2010
    2,606
    396
    hi,
    Its runs OK in LTSpice sim, attached.
    There is an error on the LM324 wiring.
    I would say pin5 and pin 1 should be linked, not pin 5 and pin 2.?
    E
  10. rijoe.mathew
    Sep 21, 2014
    42
    what is the value of C2 in this circuit
  11. ericgibbs
    Jan 29, 2010
    2,606
    396
    A 10nF will be OK.
  12. rijoe.mathew
    Sep 21, 2014
    42
    can i use .001uF or 10uF
  13. ericgibbs
    Jan 29, 2010
    2,606
    396
    Use 1nF [ 0.001uF] its OK.
    E
    Make sure you have the BC transistor pins correctly identified.
  14. rijoe.mathew
    Sep 21, 2014
    42
    can I replace the BC 337 and BC 327 with SK100 and SN100
  15. ericgibbs
    Jan 29, 2010
    2,606
    396
    hi rijoe,
    Could you please post a link to the site where the circuit design was posted.?
    The amplifier circuit as drawn will not work correctly.
    E
  16. Bernard
    Aug 7, 2008
    4,251
    424
    Looks like there will be lots of shoot thru, ie , both transistors conducting at the same time = heat. Might consider connecting as emitter followers??
  17. ian field
    Oct 27, 2012
    4,464
    792
    Are you saying you can't get 50:50 from a bipolar 555?!
    With a couple of steering diodes and a pot you can adjust the duty cycle from about 5% to about 95%.
    The best way to get accurate 50:50 is ignore pin 7 and take the timing resistor from pin 3 - this also saves the current limiting resistor from pin 7 to Vcc.
  18. ericgibbs
    Jan 29, 2010
    2,606
    396
    No, I did not say that.
    I said a version where the Output is connected to the timing components will give a 50:50 pulse period, of course pin3 is used as the output.
    Why add diodes etc, when a simple solution already exists.?
    Which will not give an exact 50:50 period anyway.
    The circuit the OP is using is driving a resonant ultrasonic transducer, so a closer 50:50 will give a better result.
    E
  19. rijoe.mathew
    Sep 21, 2014
    42
  20. ericgibbs
    Jan 29, 2010
    2,606
    396
    hi,
    I have posted a comment on his web site asking him if has actually built and tested this circuit, as it will not work as drawn.
    If I get a response I will let you know.
    E
