I do not need the voltage to ground from the battery end. I do not need the voltage to ground from the door controller end. I do not need the voltage to someplace in the many ground connections. I do not need the voltage that sags because the battery voltage goes down when current flows. I do not need the voltage from one end of a wire that is connected to another wire of a different gauge. I do not need the voltage across a splice.
Much like the measurement across the night watchman, I do not need the voltage to ground. I do not need the voltage to ground from the input. I do not need the voltage to ground from the output. I do not need the voltage to ground.
I need the voltage from someplace on one wire to someplace else on the same wire, several feet apart, while it is carrying maximum current. No splices allowed.
Just choose 2 places on the main 12 gauge feed wire and alligator the voltmeter leads on to it. Measure the distance between the two points you connected to. Cycle the window controller and notice the voltage on the voltmeter. The distance, the wire gauge, and the voltage will tell me the current.
