automatic brightness control system
Discussion in 'The Projects Forum' started by kaznov, Feb 9, 2013.
  1. kaznov
    Mar 10, 2012
    Hi guys I hope you all doing well, am designing an automatic brightness control system , but am stuck on how would I figure out what type of linear light sensor should i use that could detect a high intensity of light coming from outside a room since my project is designed to be installed inside a room .Then the system can adjust the level of brightness based on the light coming from outside a room
    any help or clarification will be appreciated
