Automated Switch
jismagic
Joined Sep 7, 2013
77
THere is a requirement to generate hi level,lo level and open position.
the simplest way is with spdt switches, power line and ground.
there is curiosity to automate it..
is there a simple automation with electronic switches?
let me know if you have seen products already in market..
jis
djsfantasi
Joined Apr 11, 2010
9,163
What will these switches drive? Is it an input to a digital signal? What will drive these electronic switches? A digital output? Do you have a schematic?
Have you considered analog switches, in the 4016 or 4066 family? Do they satisfy your requirements?
jismagic
Joined Sep 7, 2013
77
Some of the Digital inputs are pulled up to Vcc and some are pulled down to ground.
Digital inputs pulled up to Vcc are normally active lo and ones pulled down to ground are active hi.
For test purposes,
Active lo signals are connected to ground thru a switch.
Active hi signals are connected to Vcc thru a switch.
But switches are manual switches. Can i convert this to software controlled switches without an additional micro?
thanks,
jis
MaxHeadRoom
Joined Jul 18, 2013
28,702
The scope of the project is still not all that clear, for example if it requires no operator input then there is a project already out there called a Smart Relay.
Made and relabeled by several manuf, Seimens, Omron, Idec etc.
Max.
jismagic
Joined Sep 7, 2013
77
Smart relays are costly :(..
My budget is only 100 USD..
Scope: the device i make will be used for software testing! we can simulate real conditions with a switch.. I want to automate these switches and make it generic..for multiple programs..
thanks,
jis
Bernard
Joined Aug 7, 2008
5,784
4066 quad bilatteral switch. Inputs, ouyputs & control are all logic levels.
Dashed line is control. Output, pin 10, is Hi if top control, A, pin 11, is Hi & bottom control, B, pin 12, is Hi.
Output Lo if A is Lo & B is HI.
Output Open if B is Lo.
KMoffett
Joined Dec 19, 2007
2,918
So, you need X number of tri-state (hi-open-lo) logic-level signals individually switched by a USB or serial signals form a computer. How many? What type of logic are these driving...TTL?...CMOS?...???
Ken
KMoffett
Joined Dec 19, 2007
2,918
32 I/O's? Or do you mean 32 "outputs" from you automated signal generator? The signal outputs must be variable?...all simultaneously or individually? And they must be tri-state? And they must be able to provide how much drive current?
The devil's in the details!
Ken
jismagic
Joined Sep 7, 2013
77
1. yes, 32 outputs.
2. if i hook up a 12V supply, I need a 12 V output, a 15V input should give me 15V output ( Not necessarily variable output)
3. Tristate is only to simulate open condition - not pulled up to high and not pulled down to ground,
4. 100mA per channel will be great!
KMoffett
Joined Dec 19, 2007
2,918
Do you see the difference between post #14 and your first post? It's hard to help when you don't provide all the details. What are you driving that needs 100mA? Resistive or inductive loads?
Maybe you can explain exactly what you're trying to do...the overall project.
Ken
jismagic
Joined Sep 7, 2013
77
@KMoffett : attached is a simple example of a high and a low with manual switches. There are 3 possible combination altogether., high,low and open.
I want to automate these switches from my computer.
I will have like a maximum of 32 hi or lo switches..
hope this is clear
KMoffett
Joined Dec 19, 2007
2,918
OK, you need to address 64 different states. Hi/Lo logic for 32 the outputs, and Logic/Open for the 32 outputs. Can you serially change each of the 64 states, and then do whatever the purpose (might help to state that) of this operation is? Like you do manually with the the switches. Or, do all the new states have to be presented at the outputs simultaneously?
Ken
jismagic
Joined Sep 7, 2013
77
It will be either hi state or lo state or open. not all of them simulatenously.
All 32 outputs can be in one of the states hi,lo or open. Practically all outputs can be in hi OR lo OR open state.
KMoffett
Joined Dec 19, 2007
2,918
I don't understand! Can you explain what you are doing. What's the circuit/system/project that this is to control?
Ken
