Automated switch for converting a positive voltage to negative
Discussion in 'The Projects Forum' started by Raghav0211, Apr 6, 2012.
  1. Raghav0211
    Apr 6, 2012
    Hi Guys,
    I need to turn a motor in a clockwise as well as an anti-clockwise manner however lab-view can only output a positive voltage. Therefore i tried this circuit out with the motor connected to both the collector of the npn and pnp transistor. It still doesn't work. Please advise.
    Many thanks.
  2. chrisw1990
    Oct 22, 2011
    543
    41
    whats wrong with an h-bridge?
    why use a +/- power supply?
    see here forexample..
  3. John P
    Oct 14, 2008
    1,639
    225
    If you have the negative supply available, that circuit should (almost) work. But running a motor off a 9V battery, if that's what powers it, will run down the battery very fast.
    The circuit can't work because the diodes are facing the wrong way. And there ought to be pullup/pulldown resistors from the base to the emitter on both transistors. And are you really truly sure that the two transistors can never be on at the same time?
