hey guys, i would like to start a project of automating my ammo reloading press amd i need a bit of assistance on the controls. i have the mechanical side of things worked out, but the electrical side is what I am unsure of.
Here is the basic idea. i plan to use a linear actuator to run the press
up and down. The actuator needs to move the shell plate up to a specific point, stop then retract down to a specific point and repeat over and over. I found a motor controller from blue point engineering that will run the motor until it hits a limit switch, but i need to supply a 12v+ on or off control signal. here is some info on that controller. http://www.bpesolutions.com/bpemanuals/LinearControlBoard.pdf
how or what do I need to provide this control signal or is there something completely different to look at. I am open to ideas. Thanks
