MaxHeadRoom
- Joined Jul 18, 2013
- 28,700
Do you mean move the Nichrome wire wire in perpendicular to the plastic, as it is done in the typical bag sealers?So since the machine is positioned vertically , i thought about moving the NICHROM wire horizontally through the pulled down plastic ,
That is the way I see it, and the way it is done in a typical commercial bag filler and sealer.
You need some way of drawing the plastic off of the roll, over the cutting bar, stop for cut, bring down the nichrome wire, cut, return the wire head, remove the cut bag.
Or a close version of this procedure I would think.
Max.
