Automated PCB Drill
Discussion in 'The Projects Forum' started by Raed, Nov 29, 2009.
  1. Raed
    Nov 29, 2009
    I'm new in this field but I want to try making my own Automated PCB Drill.
    I'm going to use 3 stepper motors (x,y,z) and I want to make it as simple as possible.
    I searched on the internet but I didn't find any topics that describe or teach how to make it.
    Can anyone please guide me so I can do my own Automated PCB Drill?
    Thank you
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    Did you search under CNC, homemade CNC, or DIY CNC?
    John
  3. bluebrakes
    Oct 17, 2009
    245
    7
    most of the homemade ones use a dremel or similar craft drill with a relay on the power side to switch on and off.
    An old inkjet or dot matrix printer would be great for salvaging stepper motors and the axis slides.
    Have a look at the milford instruments website, they already make a 3 axis cnc drill machine but also sell the necessary stepper motors, etc for building them.
  4. BMorse
    Sep 26, 2009
    2,675
    234
    Check this out, this might give you some pointers on how to assemble the mechanics..... http://www.morse-code.com/id18.htm
    or you can watch the video here >> http://www.youtube.com/mcscoder#p/u/49/VyEQuATs2JU
    My .02
  5. shortbus
    Sep 30, 2009
    4,095
    1,685
  6. Raed
    Nov 29, 2009
    thank you so much guys
    1 more question please...
    from your experience, which Microcontroller do you think will be the best for the Automated PCB Drill and why?
  7. BMorse
    Sep 26, 2009
    2,675
    234
    well if you use discrete components to make the stepper motor controllers, you wont need one, but if you are going to use a microcontroller to control the phases of the stepper then any that has sufficient memory and pins would work, in my case I used the pic16F84a just because that is what I had on hand......
