Ive connected a dual battery isolator/combiner system and now want to run accessories off the the auxiliary battery in my van. 1) Im hooking a 750 watt inverter direct to the battery to get ac outlets, is this okay and 2) I want to run two direct dc lines with switches for two lights and one line for a dc outlet (cigarette style ) off the same battery. Do I use a terminal block/strip to connect these dc lines in series circuits? And where do I put fuses on these dc lines.....after the terminal block and before the switch? Thanks for any help. Amazing forum here by the way. Ive learned so much here already!
