Auto switch for workshop vac
Discussion in 'The Projects Forum' started by Peterkin, Aug 27, 2015.
  1. Peterkin
    Apr 29, 2013
    5
    Can anyone give me a circuit for an autovac circuit to switch a vac on when I use my bench saw
  2. GopherT
    Nov 23, 2012
    6,309
    4,029
  3. MikeML
    Oct 2, 2009
    5,451
    1,066
  4. Peterkin
    Apr 29, 2013
    5
  5. Peterkin
    Apr 29, 2013
    5
    Thanks Mike Ml
    I was thinking of using a triac instead of using a relay and wondered if any one had a circuit
  6. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Do you need a circuit? Can't you just feed both from the same switched source via a 2-way adapter/junction-box?
  7. GopherT
    Nov 23, 2012
    6,309
    4,029
    Isn't there a current transformer relay that you can put a coil around the cord of your saw, then when you start the saw, it automatically closes the relay and starts the vac (even if the vac is plugged into a different outlet/sub-circuit).
    Peterkin likes this.
  8. Peterkin
    Apr 29, 2013
    5
    No I really wanted to trigger the vacuum when I activated the saw
  9. Peterkin
    Apr 29, 2013
    5
    Yes that is what I'm thinking of, I just hoped someone may have had a circuit diagram for one
