auto reset timer
Discussion in 'The Projects Forum' started by JeffS, May 15, 2013.
Thread Status:
Not open for further replies.
  1. JeffS
    Jan 9, 2013
    5
    Hi All
    I need some help with certain aspects of my simple project, I have successfully achieved my goal using a micro however, this particular circuit needs to work on minimal component count and more importantly cost. So has to be done with ideally 1 7555/555 timer and as few as possible supporting components.
    Project Description: Door Sensor/Timer/Alarm
    The aim is to monitor status of a door [open | closed]
    On door open:
    - switches 220vac to strip lighting
    - starts adjustable timer 1 - 20 minutes
    IF on timer expiry
    - - door open - 12 vdc piezo sounds till door closed
    - - door closed - reset timer, await door open
    On door close:
    - 220vac to strip lighting off
    - turn off piezo [if active]
    Door sensor | circuit Input
    NO reed switch
    I have used both 555 | 7555 to create adjustable timer circuit no problem, however I have a few problems I cant work out how to accomplish.
    1. The output goes high on timer start and low on timer end, cant work out how to apply this to a relay | transistor to only switch piezo on AFTER timer end.?
    2. How to trigger the timer to start, and then reset timer if door closes before timer end, using only one input (door reed)?
    3. How to trigger timer as well as switch vac to lights using only one input (door reed)?
    The schematic is VERY incomplete please read it as so.
    Any pointers or ideas, schematics etc would very much be appreciated.
    Regards
    Jeff
  2. edwardholmes91
    Member
    Feb 25, 2013
    200
    20
    Why re-post something that was posted on a thread that has already been locked? Is there something that you didn't understand about Bertus' reply?
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
  4. Georacer
    Nov 25, 2009
    5,151
    1,266
    Do not re-post closed threads. Third time is not the charm.
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    For me it is, I don't like to ban people, but I will do it.
  6. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
    I closed the other thread as there was a mains powered powersupply in the schematic.
    I removed the drawing that contained the circuit, to avoid other people to get hurt or even killed.
    Bertus
Thread Status:
