audiopreamplifier
Discussion in 'Homework Help' started by Voltage87, May 11, 2009.
  1. Voltage87
    May 11, 2009
    Hey,
    i ve got a homework and that is to design a audiopreamplifier with op-amp(s).
    Input signal : U_e = 1 V, Sinus, 1Khz
    Output signal: variable Amplitude with same frequency and variable amplification factor between 0-5. I ve create a circuit but i am not really sure how to deminsion it.
    P.S. the graphic includes german resistance cause i am from Germany :)
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One generally uses a fixed gain amplifier stage, and feeds the signal in from the wiper of a pot to get the 0 - 100% variance. A follower with gain would be best, instead og the inverting amp you have drawn.
  3. PRS
    Aug 24, 2008
    989
    35
    Hi Voltage. Beenthere's advice is the way I'd do it. But wait a minute. You are showing an inverting amp where the voltage out is out of phase with the input voltage. I don't know the original problem, but if you want a gain of +5 volts you need to use a noninverting op amp whose gaine is Rf/Rs + 1.
