Audioguru's sound level indicator and gain control
Discussion in 'The Projects Forum' started by niconoe, Oct 2, 2012.
  1. niconoe
    Oct 2, 2012
    6
    I've just breadboarded the famous Sound Level Indicator from Audioguru (schematic here). This circuit provides automatic gain control.
    I have a few questions about it:
    1) All is working very well with quiet sounds, but I find it a little less helpful with louder signals (The 6-7 first leds are always on, so only 3 of them are really responding to the sound fluctuations). I'm not sure my circuit is 100% correct, especially in this "auto gain control" part.
    When I play very quiet sounds, pin 6 of the 3915 is set to 0.51v, which is correct (I think). But when I play louder sounds, it seems to float around 2v. Shouldn't it be more, something like 5.1v ? That may explain this poor response with bigger signals.
    2) As this circuit will be used in a disco (where sounds are probably way bigger than in my living room), I was thinking that it may be safer in my case to adapt the circuit to remove this automatic gain control and add some sensitivity potentiometer instead. How should do that on audioguru's schematic ? Can I simply drop Q3 and R14 and add a pot near R15 ? What value should I try here ? Should I also remove C9 ?
    Thanks a lot in advance for helping noobs like me :)
    Nicolas
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    Please post the circuit and/or a link to AG's design. Thanks.
    niconoe and Wendy like this.
  3. niconoe
    Oct 2, 2012
    6
  4. niconoe
    Oct 2, 2012
    6
    Also, this circuit used a dual opamp MC33172, which is rather hard to find where I live. Is there any equivalent (I currently use a LM358, but as Audioguru explain in the article, it doesn't work well above 4Khz).
    Thanks !
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    Simply remove R14, R15, C9 and Q3. Connect pin 6 to pin 7. Then the circuit will always be at maximum sensitivity.
    I don't know if the electret mic will be overloaded in a disco.
    Remove R6 and C2 then the 10th LED will light when the sound pressure is about 100dB.
    But years ago I measured 120dB in a disco. Then you need to attenuate the signal to 1/10th by reducing the value of R8 to 10k.
    I am just guessing about the levels because I don't have an accurate sound level meter anymore for calibration.
    The MC33172 is made by ON Semi of United States of America and by ST Micro of Italy.
    Farnell/Element14 sell electronic parts in many countries. Go to www.farnell.com and click on the flag of your country. For example, in New Zealand there are 7 DIP ICs in stock and 2506 more can be delivered in 6 - 7 working days.
  6. niconoe
    Oct 2, 2012
    6
    Thanks a lot for your answer, that's simply great and very helpful to have you here answering my noob questions !
    Thanks, will do !
    I don't understand this in detail! To me, your original circuit is a non-inverting amplifier with a gain of 101, and some frequency filtering thanks to C2. But if I remove R6, am I not asking for an (almost) infinite gain (gain = 1 + (100k / 0)). Also why do we remove C6 ?
    Thanks ! I plan to replace R8 by a 10K resistor in series with a 100k pot, I guess that would allow to configure the max signal between 100-120db, which is probably a good range here.
    Thanks, I've been able to order this IC !
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    Without R6 then the opamp is a follower with a gain of 1. Replace R5 with a piece of wire if you want.
    Good.
    Good. Where are you in the world?
    niconoe likes this.
  8. niconoe
    Oct 2, 2012
    6
    Thanks, I have it now !
    About the sensitivity pot., maybe I can have a little more flexibility here by keeping the second stage as is (1.8 gain), but by placing the potentiometer on the first preamp stage (in place of R5), to allow a wide range, such as 1-100 gain ? Or is it a bad idea for some reason ?
    I'm in Belgium. It is available at Farnell, but the shipping costs are huge if I order this alone. So I found it simpler to buy it on Ebay !
    Thanks again for your availability !
  9. Audioguru
    Dec 20, 2007
    9,411
    896
    You can adjust the gain with a pot for R5 if you want. It will be very difficult to adjust low gains if it goes as high as 100.
  10. niconoe
    Oct 2, 2012
    6
    You're right, I'll set the max gain a little lower then, maybe with a 22K (or 47K) pot. Then I guess the best way to ensure the circuit is adapted to the sound pressure range there is to test it in conditions !
