Audio transformer
Discussion in 'The Projects Forum' started by crivoli, May 6, 2006.
  1. crivoli
    May 4, 2006
    26
  2. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
  3. crivoli
    May 4, 2006
    26
    Thanks for the response.
    Here are the specs of the transformer I bought:
    impedance: 1kHz, 1V, 0mADC
    input: 1k ohm+- 10%
    Output: 8 ohms (loaded)
    DC resistance (input): 70 ohms +-20%
    DC resistance (outout): .62 ohms +-20%
    Frequency response: 300-10000Hz +- 3db
    Insulation response: more than 100M ohms @250VDC
    I looked at the links you provided but I don't know enough about the transformers to even pick one out to buy that would be a 1:3 ratio...... any suggestions on which to buy and how to tell the ratio?
    Thanks again
    -newb
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Excuse me, but the ratio of 8 ohms to 32 ohms is actually 1:4 and not 1:3
  5. crivoli
    May 4, 2006
    26
    So, Papabravo.... can you suggest a transformer that is 1:4? Any specific brand or model you prefer?
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I've never had any occasion to use one so I'm in no position to make a recommendation. I suppose you could find a toroid and some magnet wire and make your own. Challenging, but not impossible. A company called Amidon makes toroids for RF applications; they just might have ones designed for audio.
  7. legac
    May 4, 2005
    54
  8. thingmaker3
    Retired Moderator
    May 16, 2005
    5,072
    6
    Quite correct. One of these days I need to learn how to tpye.
    Crivoli, is this for your intercom? If so, you'll need a trafo with an ouput impedence of 8Ω and an input impedence of somewhere between 25 and 120 Ω.
