Hey,
I'm working on a project trying to produce physical vibrations using an analog signal from "music" files in the low 50-500 Hz range. I'm looking at 4-10 actuators to produce vibrations for a particular range of frequencies (ex one actuator for 50-100 Hz, another for 100-200 Hz, etc).
My current attempt has been to take the signal directly from an aux audio cable, amplify it, filter it using a 4th order filters and then present it to voice coil exciters, which actually vibrate at the frequency of the input signal.
My knowledge of circuit design is limited and I simply copied an online 4th order circuit to create a low pass 300 Hz filter. My first question is, is it possible to design bandpass filters with a width of about 50 Hz or less? I've been told otherwise but I wanted to ask a larger audience.
Also, I'm trying to steer away from circuits and implement something in software so I can apply some more complex algorithms for the filtering. The voice coil exciters take in an analog "AC" signal, but I think I also have the option of using AC vibrating motors. I think the speed of an AC motor is proportional to the frequency of the signal so an AC motor should capture the information present in a band of frequencies as input. What can I use to output a bunch of analog signals carrying different bands of frequencies (analyzed and separated on a phone/computer/whatever) that would be used as input to these vibrating actuators?
Thanks for any help!
