HI, I've searched the forums and can't seem to find an answer. I have a talking chess computer, I added four LED lights based on this circuit design:
http://www.instructables.com/id/Creating-An-Audio-Reactive-LED-Circuit/?ALLSTEPS
The idea is that they respond to the computer 'talking' The problem that I'm having is that the LED's are lit brightly all the time, they flicker slightly when the computer talks but not at all the effect I was hoping for. I wanted the LED lights dim way down or even off until the voice is activated. I have the base of the transistor connected to the positive terminal of the speaker. I was not sure what is triggering the transistor when there is no sound out of the speaker. I added a resistor in line from the speaker to the base hoping it would turn the LED's off until the computer talked but it only dims all the leds and does not affect the trigger point. Any advice for me? I'm a hobbyist/novice so take it easy on me. Thanks so much!!!
