Hey there,
I've been having a problem with an audio circuit I added some relays to. They were originally Pushbuttons. It's a microphone eq.
Originally when I would switch the relays on AND off, there would be a harsh click in the signal. I found out about putting a diode in parallel with the relay so that took care of the pop/click when I turn it off. However, the problem is still there when I turn the relay "on". Can I use a cap to offset this? If so, what kind and where in the circuit? (signal or power side) Diagrams or links to any def help.
Thanks for any help.
