audio preamp using NE5532 instead of LM833
Discussion in 'The Projects Forum' started by wakeke, Nov 29, 2008.
  1. wakeke
    Nov 29, 2008
    11
    I found out that NE5532 is equivalent to LM833 opamp in terms of its use/description as a low noise dual input opamp. What would be the case/prob if I replaced a LM833 opamp with a NE5532 in an audio preap circuit? Woud there be changes needed for proper functioning of the preamp?
    Answers are greatly appreciated... :D
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet and application notes for the NE5532 shows what to avoid due to its diodes across its inputs.
  3. wakeke
    Nov 29, 2008
    11
    thanks...:D
