Audio Preamp Help
Discussion in 'General Electronics Chat' started by MDK, Mar 17, 2008.
  1. MDK
    Feb 1, 2008
    22
    I'm working on a audio preamp that does not work all i hear is buzzing please take a look.
  2. nomurphy
    Aug 8, 2005
    567
    12
    There are many things wrong, most notably, no feedback. Please google "op amp design" or look at applications within a datasheet.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The opamp without negative feedback has a voltage gain of about 200,000 to 1 million.
    Its ouput is over-amplified mains hum radiation that is picked up by the input wires.
    Your two 150 ohm input resistors are in parallel and will short whatever drives them.
    What is the input from? An electret microphone?
  4. cumesoftware
    Apr 27, 2007
    1,330
    11
    It really depends on the amp, really. The LM386 has an internal feedback loop with a gain set to 20. Nevertheless if you are using other kind of amplifier, it might need a negative feedback loop. It will need a feedback network for sure if the IC is an operational amplifier.
    Please, could you specify the amp you are using?
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    An LM386 is a power amplifier. It is not an opamp and it is not a preamp.
  6. MDK
    Feb 1, 2008
    22
    The amp is a LM741CN
  7. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  8. lespaul
    Jan 30, 2008
    49
    True there are many issues with the circuit you attached. what type of audio preamp are you trying to build? Microphone preamp? Dynamic or hi-Z mic? line level or bnallanced level preamp?
    This will help determine the best circuit for the job...
  9. MDK
    Feb 1, 2008
    22
    It is a mic Preamp
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    You don't have a mic preamp.
    Instead, you have an opamp without any negative feedback so its AC and DC gain are way too high.
    The inputs are shorted together with two 150 ohm resistors in parallel.
    The input is not biased correctly.
    If the mic is an electret type then it needs to be biased.
  11. MDK
    Feb 1, 2008
    22
    who would you di it?
  12. MDK
    Feb 1, 2008
    22
    I mean how would you do it?!!!
  13. kubeek
    Sep 20, 2005
    4,686
    805
    Did you read the link?!? (???!!!?!???!?!!!???!?!?!?!??!??!!!?............ WTF)
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    You need to learn about opamps.
    The link tells you all about opamps.
