Audio power amplifier analysis
Discussion in 'Homework Help' started by foolah44, Nov 14, 2012.
  1. foolah44
    Nov 14, 2012
    I have a pre-designed audio power amplifier to analyse and test. The circuit is attached.
    I have got several values but during test some of them were not quite right.
    My results
    __________
    differential (input) stage of about (-) 65.2 - that is for Q1
    second stage gain of about 1224 - that is for Q4
    feedback ratio, about 1/25 i.i 0.04
    Overall gain of about 26
    Input impedance of about 4.4KΩ
    Output impedance of less that 1Ω
    Low frequency limit of about 32Hz due to C2
    High frequency limit of about 133kHz due to C3
    at the output stage, we assume a load of 8Ω
    Maximum operational output voltage was about 3V peak (positive)
    which gave me an operational power delivered of about 0.56W
    Power supply is about 1W
    so effieciency gives me about 56%
    The maximum power dissipated at each output transistor was about 0.51W
    So heatsink not really needed.
    TESTING
    ________
    When testing my amplifier, The low and high frequencies limits were not right. I got about 25Hz and 4MHz for low and high frequency limits.
    Can you please help me check my results. Especially for high and low frequency limits, and also power analysis?
  2. Audioguru
    Dec 20, 2007
    9,411
    896
    The voltage divider of R5 and R6 create as voltage at point A of only 0.48V which is not enough to turn on Q3 and Q5 so the amplifier WILL NOT WORK.
  3. foolah44
    Nov 14, 2012
    With Vcc = 9V, the voltage divider of R5 and R6 creates a voltage of about 1.86V.
    The amplifier work.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Why you "skipped" C5?
    F1 = 0.16/(C2*R8) = 33Hz and F2 = 0.16/(C1*Rin) = 1.8Hz and F3= 0.16/(C5*RL) = 20Hz
    so the Fd ≈ 1.1 * √(F1^2 + F3^2) = 42Hz. Simulation in LTspice show similar result.
    And are you sure that in real life you use C2 = 22μF?
    Because if C2 >> 22uF then Fd approaching to F3= 0.16/(C5*RL) = 20Hz
    How do yo get this result? Maybe this is a open loop high frequency limit?
  5. foolah44
    Nov 14, 2012
    I used a 22uF, and I had about 25Hz when measuring on CRO.
    I got the high frequency by applying Miller's theorem on C3. But it gave me about 133kHz. Which is different from about 4.5MHz observed on CRO. I believe my approach was not right. Do you have a way to calculate the high frequency limit pls?
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    I need value of a β for the BJT that you used in your small signal analysis.
    Also what voltage you assume at R4 resistor maybe you assume 1V?
    As for Fd I don't know why you get 25Hz.
  7. foolah44
    Nov 14, 2012
    I used an hfe of 330 for all BC547/BC557.
    Voltage across is VA - Vbe = 1.86 - 0.7 = 1.06V.
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Ok let's do some simplified approximation analysis.
    Input stage gain is equal to
    Av1 = (R3||rinQ4)/2re = (1.5K||1.2K)/14.85Ω = 666.666Ω/14.85Ω = 45[V/V] LTspice show 33[V/V]
    rinQ4 = (hfe + 1)*re4 = 331 * Vt/Ic = 331 * 26mV/7mA = 331 * 3.71Ω = 1.23KΩ
    2re = 4VT/Iee = 4*26mV/7mA = 14.85Ω
    Second stage (VAS) voltage gain is equal
    Av2 = (hfe+1*RL)/re4 = (91 *8Ω)/3.71Ω = 196[V/V] LTspice show 235[V/V]
    I assume hfe = 90 for BD139
    So the overall open loop gain is equal
    Aol = AV1 * AV2 = 8.82K [V/V] LTspice show 7.78K [V/V]
    Additional if we assume Cbe = 10pF and Cbc = 3pF we can find open loop roll-off frequency
    F = 0.16/ ( R3||rin4 * (cbe + Av2*(cbc+C4) ) ) = 0.16/(666.7 *9.86nF) = 24.3KHz
    And gain bandwidth product is equal to
    GBP = 8.82K * 24.3KHz = 214MHz 71MHz in LTspice
    So if close loop gain is equal to 1+R7/R8 = 26.5 the high frequency cut-off is equal to Fc = 214MHz/26.5 = 8MHz LTspice show 5.6MHz
    As you can see our calculations are as good as our model we used.
    And this is why in real life we add additional capacitor+resistor to ensure and clearly determine high frequency cut-off.
    foolah44 likes this.
