That's a clever and field expedient idea Sarge!A neat workbench is the sign of a sick mind.
Even if the caps can't be re-formed, you can gut them and use the original cases over the replacement caps to give that original look to your equipment.
Haha, I am a neat freak, that's for sure.A neat workbench is the sign of a sick mind.
Good that it's working better. Don't toss out those caps that you removed. Even though they are ancient, you may be able to revive them (once you get the proper equipment) using a process known as "re-forming". This won't work if the caps are physically damaged or the electrolyte has dried out, but it's certainly worth a try.
Yes. Once they start leaking, that's the end.Hum, well most of the electrolytics that I removed were starting to hiss, bubble, and ooze out puss looking stuff. Does this mean that they can't be revived?
Have to confess; wasn't my idea - someone else posted photos of the process on an antique radio restoration site somewhere; I don't remember where offhand.That's a clever and field expedient idea Sarge!
I do have a 0 - 3kv 0-6mA power supply with precise voltage controls. I bet that would work well for reviving caps. How do I test for leakage though?Yes. Once they start leaking, that's the end.
The process of re-forming capacitors is to bring them up to their rated voltage very slowly with a current-limited supply. When they are at their rated voltage and the leakage is within acceptable tolerance, they are ready for return to service.
You would need a DC power supply capable of generating up to the capacitor's rated voltage. Current limiting can be effected by using a suitably-sized resistor. Current should be limited to 10mA or less during the re-forming process. Ohm's Law is your friend here.
I'll probably use it to test frequency responses on audio equipment, but for the mean time i'll put it on display somewhere and use it as a conversational piece.So now you've finished what are you going to do with it, if I might ask?
by Aaron Carman
by Aaron Carman
by Robert Keim
by Aaron Carman
