Hi, I'm new to this forum and after months of searching I figured may be someone with knowledge in electronics might have the answer.
I'm a film maker and I'm putting together a camera system based on the Canon 5D mark II camera.
It's a still camera that shoots high definition video.
The problem is that, by itself, it's far from perfect. The footage is great but sound recording is bad and it's not practical in terms of handling and battery life.
To make it work well, you need a few things:
- a sound preamp to feed a signal strong enough to the camera audio input so as not to use the camera pre-amp (the trick is to bring the recording level in the camera to zero + one click that way the built in preamp doesn't affect the sound)
- an external monitor or viewfinder.
- one main battery to power the whole thing.
The problem comes when I try to power everything from the main battery. I use SWADJ3 25w switching regulators to go from the 14-16 volts of the Anton Bauer main battery to go down to 7.2v for the camera, 12v for the monitor and 9v for the external preamp.
If all the elements are powered separately, everything works fine.
If I use a common battery for everything, it generates a huge amount of noise.
It doesn't sound like a ground loop. I used ground loop isolators, no luck.
The noise fluctuates depending on what the camera does. If it's idle, less noise, if it's computing a lot (recording, using video out), there's more noise.
Someone told me it could be oscillation because my power source is not stable enough, so I built a circuit based on a LM317 (may be more stable than the SWADJ3) no luck.
I'm still convinced that I need some kind of circuit that would create two isolated completely independent power sources from one battery but I can't find anything like that on the web and my knowledge in electronic is too limited to be able to come up with one.
Any ideas would be greatly appreciated.
Thanks,
JP
Thanks,
JP
