Audio input into PIC ADC
Discussion in 'Embedded Systems and Microcontrollers' started by Synaps3, May 23, 2015.
  1. Synaps3
    Jun 5, 2013
    89
    I have a line level 800mV audio source and I want to use it with a PIC ADC input pin as a very crude VU meter (I know it won't use the full range). Will this pull down the voltage too much? I want to be able to still use the audio afterward without lowering the amplitude.
  2. Synaps3
    Jun 5, 2013
    89
    I only need this to detect an audio signal. It doesn't really 'need' to be a VU meter. I just want to be sure it is not going to effect the audio level.
    Do I need to rectify the audio signal or does it not matter?
    Can I just hook up directly to ADC pin?
  3. upand_at_them
    May 15, 2010
    246
    29
    I would buffer it through an op-amp with gain so that you get better resolution on the ADC and so that you don't load down the signal source.
    djsfantasi likes this.
  4. Art
    Distinguished Member
    Sep 10, 2007
    797
    61
    I’ve read into a digital pin and rectified it.
    I wasn’t sure it was a good idea to supply anything that can swing below zero, and your Pic ADC should read 0-5 Volts.
    Prior to rectifying it, you could use a potentiometer to bias the audio signal.
    I used LM358 to drive a condenser mic.
  5. Synaps3
    Jun 5, 2013
    89
    I found this posted somewhere. Does this need to be altered for a 800mV audio signal and 3.3V microcontroller? I've seen a version with 3.3uF, 10uF and 100uF caps. What should I use?
    Also do you think this will lower the audio volume at all?
  6. MrChips
    Oct 2, 2009
    12,652
    3,461
    Use 10μF.
    The audio volume will be ok.
  7. Synaps3
    Jun 5, 2013
    89
    Sounds good (no pun intended), but what does changing the value of C do exactly?
    I am guessing there is some frequency cutoff. What is it?
  8. John P
    Oct 14, 2008
    1,638
    225
    I'd have thought that the best input conditioning would be a "lossy peak detector" with rectification, so that you wouldn't have to catch the audio wave at its peak in order to get a measure of maximum amplitude. As for "I want to be able to still use the audio afterward without lowering the amplitude", that might depend on the output impedance of whatever supplies the signal.
    Edited to say somehow I wrote "sample and hold" when I meant "peak detector". Big duh for that one. Fixed now.
  9. MrChips
    Oct 2, 2009
    12,652
    3,461
    Yes there is. It is all about impedance.
    The source has output impedance. The ADC has input impedance. In an ideal case you want the output impedance to be low and the input impedance to be high.
    Your circuit has two 10k resistors in order to bias the signal to mid point between Vdd and GND. Together this looks like a 5k input impedance. Together with the input C you have a high pass filter. You can determine the cut off frequency for this using fc = 1/(2πRC).
  10. Synaps3
    Jun 5, 2013
    89
    So if the device I'm sending my audio into after the PIC has a rated audio input impedance of 30k, do I need to better match the resistance on the PIC ADC?
    Thanks for helping me. I know these are noobish questions :)
  11. MrChips
    Oct 2, 2009
    12,652
    3,461
    No matching required. A high input impedance means that it will not take too much current from the source.
    You will be ok.
  12. Art
    Sep 10, 2007
    797
    61
    Make R1 & R2 a potentiometer where the ADC and other side of the audio cap connected together are the potentiometer centre pin.
