Audio Hiss in simple microphone circuit, Need tips on reducing from someone who has done it before
Discussion in 'Wireless & RF Design' started by rubilacx, Mar 5, 2016.
  1. rubilacx
    Mar 5, 2016
    We are building a fairly simple circuit to take a 4-6 Ohm aviation microphone and amplify it to a military headset. We are CLOSE, but there is a small amount of "hissy white noise" in the circuit that we are trying to get out.
    Is there anyone on this forum who has conquered a similar problem?
  2. #12
    Nov 30, 2010
    16,705
    7,358
    I would guess, "yes". Probably half of us.
    The first problem is that we can't guess what circuit you are trying to use. How about a drawing of the circuit?
  3. crutschow
    Mar 14, 2008
    13,511
    3,385
    It may be possible to reduce the noise but, without seeing your circuit, it's not possible to give a good answer.
  4. Ramussons
    May 3, 2013
    562
    92
    The main source of a Hiss in low signal amplifiers is Thermal noise from Resistors and Shot noise from Semiconductors.
  5. #12
    Nov 30, 2010
    16,705
    7,358
    That is the puzzle here. With a source impedance around 5 ohms, that circuit should be a slam-dunk. I hope the Original Poster wasn't a, "drive by" who will never be heard from again.:(
    Evanguy likes this.
  6. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,708
    1,301
    Sounds like a job for a common base amp, popular in home-built intercoms.
    ak
  7. #12
    Nov 30, 2010
    16,705
    7,358
    I'd really like to see that compared to a j-fet input for noise quality. (I need the education.)
  8. AnalogKid
    Aug 1, 2013
    4,708
    1,301
    No clue, but probably not as good. It strength is using an 8-ohm speaker as a current source, turning the low impedance into an advantage. In that application it is better than a traditional voltage preamp.
    ak
    #12 likes this.
