Audio Frequency Amp
Discussion in 'Homework Help' started by celect, Jun 2, 2005.
  1. celect
    May 31, 2005
    18
    How do I determine the input signal power if the over all gain = 40db and the out put signal level = 6 watts.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    If I'm correct, you can look at the dB scale numbers as exponents. That would mean your gain is four orders of magnitude (10 to the 4.0 power). If that is the power gain, divide your 6 watts by 10,000 and there you are.
  3. n9xv
    Jan 18, 2005
    329
    Gain factor = 10 raised to the exponent (dB-gain / 10)
    So,
    10^(40/10) = 10^4 = 10,000
    Therefor,
    Input power = 6/10,000 = .0006 or 600-uW (microwatts)
  4. davidand
    Jun 2, 2005
    43
    thanks for info, I now understand the text.
