An electret mic and the resistor that powers/loads it are a faily high impedance (about 2.5k). If an inverting opamp is used then its low input impedance might reduce the output of the mic.
So a non-inverting opamp with a fairly high input impedance (12.5k and higher) is the best preamp circuit.
I will go with the non-inverting opamp then. You mention the preamp circuit, isn't that just the use of a vcc to a resistor and capacitor off the positive point of the mic? Are you talking about using the opamp as the pre amp?
Thanks. I'm planning on using the LM358n. I might need some assistance on the schematic for this circuit.
Question: Does the electret mic create AC? Impedance relates to AC from what I understand. I plan on using a 9v battery for this, that's not AC.
An LM358 is too noisy (hiss), has high crossover distortion and has a bandwidth too narrow to be used as a mic preamp. Many low noise opamps are made. I use a TL071 single, TL072 dual or TL074 quad opamp that are low noise, have very low distortion and have a bandwidth that goes high enough for audio.
