Well never underestimate the placebo effect. I am into wine tasting also, and I shudder then someone praise a wine just because it is expensive and therefore should taste good. But I guess the really expensive HIFI gear pushers laugh all the way to the bankThis is some snippets off an audiophile board:
The "form" was too good to pass up.
No, I've heard them sing live: the bass was weak and the midrange sounded hollow.Since all artifical sources are imperfect and all auditoria have flaws I recommend benchmarking sound reproduction systems against the only pure sound source - a choir of angels in the only unbounded auditorium - heaven.
Quote:
Originally Posted by rjenkins
Speaker cables can drastically affect the sound:
A higher series resistance reduces the time constant of an inductor, so thin, higher resistance cables increase the treble output from speakers, which can make them sound tinny in comparison to the same speakers with heavy, low resistance cables.
Anyone who knows the Thiele-Small equations for speaker building knows that increasing series resistance increqses the speaker "Q", causing a higher hump in the woofer's response at its resonant frequency. The sound will be BOOMY, not TINNY.
Bob
That explains why it didn't work. I kept pouring it into my ears....The best stuff is that "varnish" you can buy that has the *same density as the little bones in the human ear*. You paint it all over your caps and PCBs and transistors etc and your amp sounds MUCH better..
