Hi Guys,
I purchased a stereo valve amplifier today, and it sounds nice
I also have a subwoofer enclosure with it's own active crossover circuitry and amplifier.
I want to use the subwoofer enclosure with the valve amplifier
(hopefully far enough away that the vibration doesn't kill the valves).
I understand I need a mono signal for the sub that is the common of both left and right.
It would be possible to simply connect the left and right input signals together,
but then there is no stereo signal for the valve amp.
Could I use 10K resistors in this circuit to do the job?
Is there a better value to use?
