Umm...I'm not sure what I would use as the low voltage attennuation, I was thinking of really lowering the voltage, like a max of 13v for use with a common OP amp operating voltage. Right? I'm not sure what the lowest would come out to but I figured I could maybe use some sort circuitry to have different attenuations that adjust. In my orignal post I added something like using an addition OP amp to do this task.But what is the low end of your peak voltage range? A differentiator becomes more problematic as the voltage is reduced, because dv/dt of the normal signal is reduced.
Do you want to have one attenuator work for the entire range of peak voltage, or can the attenuator be switched? I suppose it could adapt to the peak voltage, but that gets pretty complicated.
What do you think? What low end voltage is troublesome for the task?
