Audio Capacitor-resistor delay
Discussion in 'The Projects Forum' started by stellarpower, Feb 19, 2009.
  1. stellarpower
    Feb 19, 2009
    28
    Hi, can anyone tell me how to make a delay circuit using capacitors and resistors? I know that a lot of people have asked about this before, but I'm a bit confusabubled. The circuit is for an analogue audio equalizer thing.
    Thanks.
  2. mik3
    Feb 4, 2008
    4,846
    63
    What will be the function of the delay?
    Maybe you meant peak detector?
  3. stellarpower
    Feb 19, 2009
    28
    The EQ us supposed to work by splitting the input, and delaying one side by a few milliseconds, and then joining it up with the original, where the waves cancel each other in certain ways, and attenuating different frequencies in different ways.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  5. mik3
    Feb 4, 2008
    4,846
    63
  6. KL7AJ
    Nov 4, 2008
    2,043
    292
  7. stellarpower
    Feb 19, 2009
    28
    Could any of you guys explain how your suggestions work, as I'm a bit of a beginner at electronics. Thanks a lot!
  8. KL7AJ
    Nov 4, 2008
    2,043
    292
    A bucket brigade is a LONG string of capacitors, with a sample-and-hold circuit (generally an FET) between each one. With a clock signal, you transfer the charge from each capacitor to the next one in line. You then have to INTEGRATE (use a low pass filter) at the end to average all the charges together, and get an analog signal back out.
    The SAD512 uses 512 stages of capacitors and sample-hold devices. I don't THINK you want to build this out of discrete devices...but you could!
    Eric
  9. stellarpower
    Feb 19, 2009
    28
    Do you know where I can get a BB without paying a load? They seem to be pretty much obsolete now.
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Sad to say, it looks like the remaining devices are in the clutches of warehouse operators. They have literally zillions of obsolete IC's, but usually only on bids of $500 and up. You can probably find Intel 4004's at some of them.
  11. stellarpower
    Feb 19, 2009
    28
  12. stellarpower
    Feb 19, 2009
    28
