audio buffer??
Discussion in 'General Electronics Chat' started by lokeycmos, Mar 21, 2011.
  1. lokeycmos
    Thread Starter Active Member
    Apr 3, 2009
    432
    7
    could someone please explain what an audio buffer is? im checking out wah wah circuits and the red part in the attached schematic was called an audio buffer by the author. TY
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The configuration is that of a source follower. The similar vacuum tube circuit was called a cathode follower. There is no inversion from input to output and the gain is usually unity. An "audio buffer" is a unity gain amplifier with a flat response over the audio frequency range.
  3. lokeycmos
    Apr 3, 2009
    432
    7
    could you dumb it down for me?
  4. kubeek
    Sep 20, 2005
    4,691
    806
    An amplifier with gain of 1 (i.e. no voltage amplification), that doesn´t load the output of the previous stage but allows you to load its own output for example with headphones.
    It is used because loading the previous stage would cause undesired effects, like different frequency range for different headphones.
    Dumb enough?
  5. lokeycmos
    Apr 3, 2009
    432
    7
    yes, dumb enough. makes perfect sense now
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Sorry that is beyond my capabilities
