Audio boosting circuit help
Discussion in 'General Electronics Chat' started by Razor Concepts, Jun 25, 2009.
  1. Razor Concepts
    Thread Starter Active Member
    Oct 7, 2008
    212
    Here is a circuit that boosts audio levels to 0-4v.
    http://macetech.com/vuinput01big.png
    What I do not understand is why the battery is connected to the non-inverting input of the op-amp. I breifly tried this setup with my mp3 player and I nearly fried it :eek:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Where do you see such a connection? The non-inverting input is attached to the common point between R5 & C2.
  3. Razor Concepts
    Oct 7, 2008
    212
    There is that circular symbol labeled V2, is that a voltage source?
  4. Audioguru
    Dec 20, 2007
    9,411
    896
    The circuit is wrong because it has nothing to limit the negative swing of the input signal. If the input was changed to be an inverting amplifier then a negative input swing would be allowed.
    If the existing circuit used an additional negative power supply then it would work fine.
    EDIT:
    Audio booster? No.
    It is a peak detector circuit with a DC output.
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Must be why the output feeds an ADC.
