Audio - Auto Detection of Line In / Mic In
Discussion in 'General Electronics Chat' started by csumod, Feb 6, 2009.
  1. csumod
    Feb 6, 2009
    Hi All,
    My project needs auto detect requirement for distinguishing Line In or MIc In after the audio equipments has been connected. Please let me know how it can be done.
    Sumod C.
  2. italo
    Nov 20, 2005
    205
    the jack when not in use is shorted when you plug it in it opens. that can be detected and light a LED.
  3. Externet
    Nov 29, 2005
    775
    57
    Distinguishing or self adjusting to any ?
    It would be detecting/reading the self-setting condition of an automatic volume control circuit. But that would not work moments when input is silent.
    AudioPrecision test equipment has autoscaling. Some multimeters too. Try an autoscaling circuit, and read its status.
    Miguel
  4. csumod
    Feb 6, 2009
    Thanks for the quick reply, my requirement is to distinguish whether the connected device to be treated as Line in or Mic in through a 3.5mm connector
  5. flat5
    Nov 13, 2008
    403
    17
    Line in is usually 10k ohms, I think.
    Mic in will be much lower for dynamic or electret mic.
    For electret mic input there very often will be a voltage available to power the mic. You could detect this.
    Good luck.
  6. Externet
    Nov 29, 2005
    775
    57
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    My local TV station has a circuit that automatically adjusts sound volume to the signal's level.
    When a new picture occurs the audio gain is maximum for about 1 second then it drops to normal sound. It is deafening.
  8. Søren
    Sep 2, 2006
    472
    28
    That might be a better solution than just checking the amplituide, since you won't know if you have a line in until the signal gets positively above a certain level for a short time (longer than any possible transient). And if the level goes down, it will up the gain once more... Bad solution.
    It has to be quite a clever design to give a high quality on both mic and line level signals.
    I'm much more in favour of a switch - possibly one that defaults to line in level.
  9. csumod
    Feb 6, 2009
    I did some search on the net. I found Universal Audio Jack and Jack Sensing performs the need I require. But Iam not sure how to implement.
    Please any body let me know regarding these technologies. I also learnt Jack Sensing works on Impedance sensing.
