Your tiny cheap tweeters are rated for 5500Hz and up. Frequencies below 5500Hz might blow them up. Good larger tweeters start at 2500Hz or 3000Hz.i want to make one amp for the mid and tweeters. ill run the same frequencies through both of them.from maybe 500Hz and up. everything below 500Hz and below through the sub. that can work, right?
