thank you, a good start from someone who knows the ropes is what i need. i want to learn how and why it works, not just build it. so a good start will help, i can ask questions when road blocks come. thank you very much
the sub is a rockford fosgate 8" (p28s8 is the part number,)
for 12v use, rated at 8ohms, 200w rms and 400w max frequency range between 43-250Hz
the tweeters are also car tweeters, rated at 6ohms Power Handling: 20watts RMS / 40watts Max - 87dB
Range: 5,500 - 20,000 Hz
the supply is 12v 20a
i havent chosen the mid yet, but have plenty to choose from
