audio amplifier
Discussion in 'Homework Help' started by salmanshaheen_88, Mar 30, 2010.
  1. salmanshaheen_88
    Thread Starter Active Member
    Mar 5, 2009
    88
    anyone can give me audio amplifier circuit using transistor (Pnp or Npn), plz indicate the values of components as well
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
  3. salmanshaheen_88
    Mar 5, 2009
    88
    I don't need such info, plz help me I am very frustrated with this project
  4. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Show us what you got.
    That way we can help you.
    Bertus
  5. salmanshaheen_88
    Mar 5, 2009
    88
  6. Jony130
    Feb 17, 2009
    3,991
    1,116
    Look at all PNP audio power amplifier.
    And we don't use workbench here. Post your diagram in PNG or JPG.
  7. salmanshaheen_88
    Mar 5, 2009
    88
    the problem is that the output signal is not amplifying, it has same amplitude as input signal
  8. t06afre
    May 11, 2009
    5,939
    1,222
    "And we don't use workbench here" What do you mean by that? Every member in this forum is free to use the tool he/she prefer. I use Altium Designer.
  9. salmanshaheen_88
    Mar 5, 2009
    88
    if you don't use workbench then make this circuit in altium and analyze it
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    Your extremely simple circuit is missing a speaker. So it has no power supply and has no load. Connect an 8 ohm speaker in parallel with the oscilloscope and see what happens.
    The speaker and the second transistor will get hot.
  11. salmanshaheen_88
    Mar 5, 2009
    88
    I have used signal generator instead of microphone and oscilloscope instead of speaker
  12. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    An osciloscope has most times an input resistance of 1 M or higher.
    You are testing the circuit with this resistance.
    Try a resistor of 1K accross the inputs of the scope and see what happens.
    Bertus
  13. t06afre
    May 11, 2009
    5,939
    1,222
    I think then OP say a scope he/she is refering to a virtual scope in the software;)
    Edit: I also think the OP should apply some voltage to the transistor base bias network. Something is wrong with the schematics
  14. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    According to your schematic.
    Your osciloscope is being used as a series resistance from the positive battery terminal. So you have no positive supply to the circuit itself.
    The osciloscope needs to be connected to ground and one terminal to the collector of the transistor stage,
    You need to put a collector resistor in the collector loop, or you will not develop a voltage at the output with no collector resistor.
    Essentialy what your reading is the signal itself coming through the top resistor from the signal generator. Bypassing the trasnsistors all together.
    Here is how to hook up the oscilloscope for input and output readings with respect to a common signal ground.
    With no load.
  15. salmanshaheen_88
    Mar 5, 2009
    88
    thank you soo much Hobbyist now the only problem left is that my signal at channel B is not amplifying, I mean its amplitude is same as the signal at channel A, how I should increase the amplitude of the output signal???
  16. hobbyist
    Aug 10, 2008
    773
    62
    Here is your circuit, with the same values you used, note the 10 ohm collector resistor, and all the settings on the osciloscope, and functrion generator. As well as the circuit configuration.
  17. salmanshaheen_88
    Mar 5, 2009
    88
    hats off to you, im very happy from you.
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    Notice that the extremely simple class-A "amplifier" has a voltage gain of only 10.
    If you use a microphone then you must add a preamp with a voltage gain of about 20.
  19. salmanshaheen_88
    Mar 5, 2009
    88
    ok one more question if you can see in the diagram the input signal and output signal are out of phase, what should i do to make the phase of both the signals same???
      File size:
      121.1 KB
      25
  20. salmanshaheen_88
    Mar 5, 2009
    88
    hey guru I have to show the waveform first to my professor and then my job will be to implement this circuit on bread board and I will have to use mic as input signal and speaker as output, so tell me how many ohms speaker I should select and which type of mic???
