I have dual frequency generators built from 4046 VCO's. The outputs of each go to a dual input NAND gate with a 10V supply voltage, this signal then goes to another dual input NAND gate (signal splits and goes to both inputs of the NAND gate) that also has a 10V supply voltage.
I want to use the output from the NAND gate to power the base of a BJT, with a pot and resistors to control the base voltage.
Will the NAND gates act as amplifiers in this circuit?
What kind of transistor do I need? I want something that can carry at least 3 amps in the audio frequencies.
