Audio Amplifier Repair Advice
Discussion in 'General Electronics Chat' started by Melkor, May 3, 2013.
  1. Melkor
    Mar 31, 2013
    Hi !
    I have a Marantz PM-66SE audio amplifier.
    The problem is a nonlinear imbalance between the channels.
    What I mean is that under an identical stereo test signal one channel measures from under 10% louder ( at lower volume levels) to over 40% louder (at higher volume levels).
    Any ideas about possible causes ?
    Thank you.
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
    One channel has an increase in gain or lower in gain compared to the other channel, do you have the service manual?
    Is the balance set correct?
  3. studiot
    Nov 9, 2007
    5,005
    515
    Equally (pun intended) are you certain that the same signal was supplied to both channels?
  4. #12
    Nov 30, 2010
    16,704
    7,351
    There could be a dozen reasons, from cheap volume controls to dirty connections in the speaker wire.
    A sound level meter is a tool. It enables you to find the difference, then find the cause, then find out if the amplifier is fixed. If only the sound level meter was here so we could see it as we ran all the adjustments through their range and wiggled the wires.
  5. Melkor
    Mar 31, 2013
    Sorry. I don't have the service manual.
    All I could find was the attached schematic.
    But wouldn’t a difference in gain be constant - independent of volume ?
  6. Melkor
    Mar 31, 2013
    I used a 4000Hz square wave. The other channel I obtained by doing a copy of the first one.
    I checked the stereo wave before writing it on an audio CD.
    I used a a CD player with that CD as a source.
    I checked both the CD output and the amplifier output with an oscilloscope.
    So I’m pretty sure that the same signal was supplied to both channels.
  7. Dodgydave
    Jun 22, 2012
    5,155
    772
    Ok can you input the same signal into both channels at the same time by shorting both the left and right inputs together, and see what the signal is like at the wipers of the volume control with the scope?
  8. studiot
    Nov 9, 2007
    5,005
    515
    That would be the conventional way to check or adjust channel balance in stereo amp. You should check at various stages through the amp from input to output to localise where any discrepancies occur, not just at the volume control.
  9. bountyhunter
    Sep 7, 2009
    2,498
    507
    Did you have a 8 Ohm load on both channels when you measured the output signal?
  10. bountyhunter
    Sep 7, 2009
    2,498
    507
    If there is a load on the output, that apparrent gain (measured) depends on the output impedance of the amp which can vary for a number of reasons.
  11. studiot
    Nov 9, 2007
    5,005
    515
    Good point. Is the amp rated for 8 ohms or 4 ohms?
    The loads need to be proper resistors not speakers.
  12. Melkor
    Mar 31, 2013
    It is rated 50W at 8 ohms.
    I don't have resistors with this amount of dissipation power.
    I will try to get a resistive dummy load of this amount of power before testing again.
    Do you think it is possible that the trouble is with the loudspeakers ?
  13. studiot
    Nov 9, 2007
    5,005
    515
    I once made some (speaker and power supply) testing non inductive loads by from old electric fire wire by determining the length for 1 ohm and hammering two rows of copper nails, set this distance (about 120mm) apart into a base board.
    The nichrome wire was then would round back and fore between the nails in a zig-zag fashion, above the baseboard in free air for cooling.
    This created resistors with taps at 1 ohm intervals. I could get a pair onto the baseboard.
    It was very cheap and very successful, though not very pretty.
  14. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Number 1 trick of fixing weird audio amp faults... Swap stuff!!
    Swap the speakers from right to left, if the problem swaps, then the fault is the speaker. :)
    If the amp has 2 power amp modules, then as another test you can swap them. If that swaps the weird fault then you proved the fault is inside the module.
  15. studiot
    Nov 9, 2007
    5,005
    515
    This is a really good service technique that has far wider applications than just audio amps.
    It's official name is test by substitution.
  16. Gary_P
    Apr 4, 2013
    7
    Where is the volume control?
    Is the volume control being used to adjust the signal level?
    Most potentiometers have pretty bad tracking channel to channel.
