Audio amplifier (BJT) using BC182BP
Discussion in 'Homework Help' started by vibz90, Nov 1, 2009.
  1. vibz90
    Oct 24, 2009
    21
    Hello
    I have to build a BJT amplifier using BC182BP transistor, to amplify the sound of DOM5242L_R (the mic to be used) to be fed in a normal pc.
    The resistors and the capacitors of the amplifier should be based on the gain depending upon the values of mic and the input value of the sound card (or any such thing in pc).
    I have found the basic circuit .The output will be connected through a 3.5mm jack and the input voltage is supplied from the mic, i just need to know the gain and the value of resistors and capacitors accordingly....
    i have attached my circuit with this file.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
