audio amplifier 50 watts minimum
Discussion in 'Homework Help' started by ajdizonm, Mar 1, 2010.
  1. ajdizonm
    Mar 1, 2010
    8
    Hi. I'm Arman and I'm a student. We are required to submit a final project;
    Audio Amplifier 50 watts minimum using only discrete transistors.
    I planned it using class AB configuration and it still wont reach the minimum.
    I use a DC Power supply +15 and -15 output...
    Can somebody help me??
    start again from scratch...anyone?:(
    thanks.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the nature of your problem? As a hint, study difference amplifiers and operational amplifiers.
  3. ajdizonm
    Mar 1, 2010
    8
    no matter how i design the circuit it wont reach 50watts power output. I use discrete transistors.BJTs
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Try to use higer supply voltage. Can you post your design also?
  5. ajdizonm
    Mar 1, 2010
    8
    Here. I assume an AC Vin signal, 5v max voltage, 40khz.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    40 KHz is well above the audio spectrum. have you looked at other designs for amplifiers? That should give some guidance - especially if you analyze how they operate.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    The first rule of thumb in amplifier design is not to try and get some large gain in one step(stage). What do I mean? Well think about going from say 400 mV(RMS) at 50mA(RMS) for a power level of (0.4*0.05 = 20 mWatts) to 50 Watts. That is a gain of 10*log(50/.02) = 34 dB. That is quite a bit of gain for one stage. It will be better to get that 34 dB of gain in two or three stages.
    A better approach would be two stages of say 20 dB and 14 dB or even three stages of say +14 dB, +10 dB, and +10 dB. That's my $0.02 your mileage may vary.
    ajdizonm likes this.
  8. daviddeakin
    Aug 6, 2009
    207
    27
    For a simple design like that the power output will always be limited by the supply voltage to:
    P = V^2 / 2R
    With +-15V supply and a 4 ohm load load you can't get more than:
    15^2/(2*4)= 28W.
    You would need greater than +-20V supply to achieve 50W into 4 ohms, or more than +-28V for 50W into 8 ohms.
  9. ajdizonm
    Mar 1, 2010
    8
    What would be the configuration in the output stage that would likely compliment if I were to use class AB configuration on the driver stage?
    I only know concepts about the configurations, and I lack knowledge how to use/ put them all together... to make a sensible amplifier...
  10. Audioguru
    Dec 20, 2007
    9,411
    896
    Your amplifier does not amplify because it is just two emitter-followers that have no voltage gain.
    You need a voltage amplification stage, not a driver stage because your transistors are darlington transistors that already have a driver transistor driving the output transistor.
    Because your transistors are both darlington transistors they operate in class-B, not class-AB because two darlington transistors must be biased with 4 diodes but you have only 2 diodes.
  11. daviddeakin
    Aug 6, 2009
    207
    27
    The bible for this type of amplifier is this one by Douglas Self:
    http://books.google.com/books?id=BR...&cd=1#v=onepage&q=small signal stages&f=false
    Maybe your local library has it?
    See page 151 which shows typical output stages with voltage amplification, and also page 75 onwards.
  12. hobbyist
    Distinguished Member
    Aug 10, 2008
    774
    65
    Are there any constraints whatsoever, to work under??
    Such as VCC, load impedance, voltage or power gain,...ect...
    Or is the only constraint 50 watts min
    using discrete components only??
  13. ajdizonm
    Mar 1, 2010
    8
    yup. 50watts minimum using discrete components only...
  14. ajdizonm
    Mar 1, 2010
    8
    I have another question...
    we've found a ckt that can produce a minimum of 50 watts... now, it is a bit of an issue for us, locally,that we can't find a proper speaker that can take an average of 80 watts out with 8 or 4 ohms impedance.
    The question is, is it possible to series a resistor before the speaker so that the power output can be minimize? so as it can't damage the speaker?
    thanks!!!!
    Another thing,
    What possible equivalent transistors are there for:
    NSDU57 - PNP 2W 100v 70MHz 1A TO-202
    MPSA70 - PNP TO-92
    MD8003 - NPN
    TO-78
  15. Audioguru
    Dec 20, 2007
    9,411
    896
    A 50W amplifier has an output of 20V RMS into 8 ohms.
    A speaker has a resonant frequency that makes it sound "boomy" if its resonance is not damped by the extremely low output impedance of a modern amplifier. So if you connect a resistor in series with a cheap speaker to reduce its power then it will sound "boomy".
    PA systems use a transformer at each speaker to reduce the power fed to each speaker.
    But their voltage is much higher than 20V so if you use one the power to a cheap speaker will be very low.
    Home entertainment stores sell a switched transformer for homes that is mounted as a wall switch.
    You listed extremely old transistors. So the circuit you found must also be extremely old.
    Why not use a modern circuit? Aren't you supposed to design the amplifier yourself instead of simply copying one?
  16. ajdizonm
    Mar 1, 2010
    8
    presentation is on friday, besides, its not the only subject that i'm enrolled. Instructors are getting a bit fierce. they demand this and that, we dont have much time.
    were doomed. T_T
  17. ajdizonm
    Mar 1, 2010
    8
    Is there any equivalent for and old MD8003/MD8002 NPN transistor?
    We have managed to find equivalent for the other two..
    thanks
  18. Audioguru
    Dec 20, 2007
    9,411
    896
    Thousands of new transistors can replace very old and obsolete transistors.
    Simply calculate the max voltage, max current, minimum current gain, max frequency response and max power dissipation of the transistors needing replacement and select new ones having the calculated spec's.
    EDIT:
    www.datasheetarchive.com shows that they are old low power dual transistors. An audio amp circuit does not need and does not use dual transistors.
