Audio ampifier noise
Discussion in 'The Projects Forum' started by AVOLLC, Feb 4, 2015.
  1. AVOLLC
    Feb 4, 2015
    5
    Hello, everyone. I am attempting to make an audio amplifier for a microphone. I am having problems with noise in the output. The noise is about 1/10 the signal level and would clearly by audible. The microphone in use is my POM-3535P-3-R. It has a SNR of 68dB which should be more than enough for a quality signal. I have uploaded a schematic to this link. Any help is appreciated.
  2. #12
    Nov 30, 2010
    16,670
    7,314
  3. AVOLLC
    Feb 4, 2015
    5
    Thank you for your reply #12
    I have attempted to replace the input amplifier with an lm833 (4nv/Hz). However, this has not fixed the issue. In fact, it has more noise now. Any idea as to why this would be the case?
    --AVO
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    You used an 1K resistor to bias the mic.
    Electret mics seem to work the best when biased with a current of about 1 mA.
    Make the 1K resistor 10K and try again.
    Also the first transistor depends now on the same resistor.
    Bias the transistor seperate and put a capacitor between the mic and transistor.
    Bertus
    #12 likes this.
  5. #12
    Nov 30, 2010
    16,670
    7,314
    What you connected to the first transistor base in the first drawing should connect to the left side of the 1uf capacitor with no problems.
    Notice I said, "should".
    I've been fooled so many times that I get cautious. :(
  6. AVOLLC
    Feb 4, 2015
    5
    Bertus, thanks for replying. I am however a little confused about your response. No DC should flow through the cap, so why would it need to be separated from the bjt?
    Thanks again!
  7. AVOLLC
    Feb 4, 2015
    5
    I just discovered that the his vanishes if I touch the end of the mic with my finger. Could it possibly be picking up random air currents?
    --AVO
  8. ronv
    Nov 12, 2008
    3,393
    1,454
    How far is the mic from the transistor?
    Is the signal wire shielded?
    Is it battery operated or does it have a power supply.
    Do you have any decoupling caps?
  9. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
  10. AVOLLC
    Feb 4, 2015
    5
    Bertus: Thank you for the link. This appears to use a jfet amplifier instead of my BJTs (radoshack model). I heard jfets are superior for audio, is this the case?
    ronv: The microphone is powered by a 9V battery, I have a 440uF decoupling cap between the rails of the supply.
  11. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
