Audio Amp Circuits
Discussion in 'General Electronics Chat' started by Firestorm, May 8, 2005.
  1. Firestorm
    Thread Starter Senior Member
    Jan 24, 2005
    353
    Hey,
    I am playing around with some old speakers and and found 4 0-5W/8Ω speakers.
    I am wanting to hook them up to my cd player and was thinking about building an amp for it. What size amp would I need? Some1 suggested the 386.
    I am wanting to build bigger amps as well but don't really know much about them. Want to eventually build 1 for my truck once I turn 16(21 days lol :)). Can anyone guide me in what to look for when building an amp and the info needed b4 I start. Sorta new in the whole audio part. Thanks l8er
    -fire
  2. legac
    May 4, 2005
    54
    Hi
    I think you can try TDA 2030 or LM 1875 Do a google search, you will see a lot of projects based on those tiny chips
    Cheers
    legac
  3. mozikluv
    Jan 22, 2004
    1,437
    hello firestorm,
    is that a 0.5w spkr or 5w spkr. if it's 0.5w, the LM386-4 will do. you will have to make 2 sets for stereo.
    if it is 5w, the TDA1524 will do. it is a 4 channel single chip audio ic. it has a 5w output per channel. that is a very versatile chip in which you can bridge it or parallel it or bridge/parallel it. however it has a small drawback, it's a class B ic power amp.
  4. Firestorm
    Jan 24, 2005
    353
    thx for the replys moz and legac.
    each speaker is 5W.
    What exactly does a class B power amp mean?
    With the 4 channels, does this mean each channel can be hooked up to a speaker and each have 5Ws of power? What is the benefit of bridging or paralleling it? Fixin to check out the datasheet on these chips :). thx again
    -fire
  5. mozikluv
    Jan 22, 2004
    1,437
    hi
    by bridging you increase the power output and by parallel you increase the power dissipation capability of the chip while still retaining the original power output. :D
  6. Firestorm
    Jan 24, 2005
    353
    :) thx for the help, just looked at the datasheets and will hopefully figure it out after some sleep :)
    thx again
    -fire
  7. David Bridgen
    Feb 10, 2005
    278
    A stage operating in class A conducts throughout the whole of the input cycle.
    ................................ class B conducts during half the input cycle.
    ................................ class C conducts during a small portion of the input cycle.
    Dissipation in class A is highest.
    Dissipation in class C lowest. You won't see class C used for a.f. It is used only for some r.f. applications.
