Audible noise in dc motor
Discussion in 'General Electronics Chat' started by Vindhyachal Takniki, Mar 21, 2016.
  1. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    1. I have a simple application in which three dc motors are controlled by MCU with a mosfet.
    Motor is 12V dc motor & load is small robo tyre as in attached video. This is not much load & moreover tyre dont move on road it is hanging upwards so no friction of road or anything.
    2. Problem is as you can hear motor produces too much audible noise , is there any way to reduce it or any silent 12Vdc motor. SO that when motor rotates no noise or little noise is produced. I need 150rpm or 200rpm motor.
  2. crutschow
    Mar 14, 2008
    13,474
    3,361
    Why did you double post?
  3. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    prob by mistake.
  4. blocco a spirale
    Jun 18, 2008
    1,457
    369
    You could try wrapping something around the body of the motor and gearbox to absorb the sound. Generally speaking, the more you pay for a gear motor the quieter and smoother it will be. Look out for Maxon or Escap geared motors on ebay, they cost a fortune to buy new but are affordable as surplus of used parts.
  5. DickCappels
    Aug 21, 2008
    2,753
    665
    Duplicate thread has been deleted.
  6. Alec_t
    Sep 17, 2013
    5,967
    1,134
    Is the noise a whine produced by the FET switching current on/off, or is it gearbox/mechanical in origin?
  7. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    its the gearbox. Are dc motor available for 12Vdc,150rpm, which dont produce this geared noises & can bear a tyre load as in video?
  8. Sensacell
    Jun 19, 2012
    1,183
    276
    I used to design cinema camera electro-mechanical accessories, they had to be super quiet for sound on movie sets.
    It's true that the quality of the gearbox is the most important factor, a high quality motor / gearbox will cost $300-$500 to get it (almost) silent.
    Trying to cover the motor with sound absorbing materials won't help much unless you rubber mount the motor AND use a vibration isolating coupling on the output shaft- the gear on the final drive couples lots of vibration into whatever it's driving- producing noise.
  9. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Planetary gear boxes or worm & pinion are among the quietest but are expensive, simple gear reduction types are typically noisy.
    Max.
  10. Vindhyachal Takniki
    Nov 3, 2014
    357
    6
    I will try with stepper motor to see result rather than dc motor. i ahd tried two other d motor but same results
  11. MaxHeadRoom
    Jul 18, 2013
    10,832
    2,502
    Stepper motor are traditionally very noisy, usually more so than a DC brushed, the quietest is BLDC.
    Max.
