atx transformer
Discussion in 'General Electronics Chat' started by kyu9971, Apr 21, 2015.
  1. kyu9971
    Mar 28, 2015
    57
    Hi everyone,
    I have an question to do.
    Can i use an transformer of a pc power supply (atx type) in reverse mode, in order to have an in dc high voltage output with 12vdc in input?
    Of course using an appropriate pwm circuit as oscillator to High frequency.
    thanks kyu9971
  2. Alec_t
    Sep 17, 2013
    5,971
    1,135
    You need AC to drive a transformer; not pulsed DC.
  3. kyu9971
    Mar 28, 2015
    57
    Ok, thanks for your reply,
    but into the pc power supply the ac voltage is first converted in dc and after send to transformer with pulse.
    Is it wrong?
    can you explain better please.
    thank you
    Kyu9971
  4. Alec_t
    Sep 17, 2013
    5,971
    1,135
    Perhaps I was a bit hasty with my reply. Yes, a switched-mode power-supply works that way, but the primary winding is designed to withstand the inductive high voltage generated when the switching device switches off rapidly. The secondary (low voltage) winding insulation may break down if subjected to such high voltage caused by square-wave drive currents, but should be ok if driven with a sinusoidal current.
  5. tom_s
    Member
    Jun 27, 2014
    287
    342
    atx supplies go (after rectification) high voltage dc to low voltage dc
    you are wanting to go the other way? -> low voltage dc to high voltage dc
    simple answer is no.
  6. kyu9971
    Mar 28, 2015
    57
    Ok,
    so i will must make before one sine wave and after drive the transformer.
    some suggestion on to start?
    thank you
  7. AnalogKid
    Distinguished Member
    Aug 1, 2013
    4,691
    1,297
    I disagree. The switching currents in the secondary undergo almost exactly the same high-frequency content as the current in the primary. It is, after all, a switching power supply transformer. I see nothing wrong with driving the secondary with switched low voltage/high current, and getting switched high voltage / low current out of what was the primary.
    BUT - without knowing a lot about the transformer, such as primary and secondary inductances, mutual inductance, etc., it will take a lot of fiddling around to get an efficient circuit. It never will work as well as a supply (and transformer) designed from the ground up to do what you want. Almost any topology other than flyback will reduce or eliminate driven-side inductive kicks.
    ak
  8. shortbus
    Sep 30, 2009
    4,095
    1,681
    Just a question on this statement. Are you saying they use two types of magnet wire to wind a transformer? I always assumed that the only difference was the gauge of the wire was different not the insulation?
  9. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    A sine wave might work, but that's not how the transformer in an ATX supply is driven in normal operation. Normally, the full 370 volts DC is applied across the primary for a few microseconds, then removed for a few microseconds. This process is repeated maybe 50 or 100,000 times a second. So the voltage input is more like a rectangular wave, and the current input is more like a triangle.
    In theory, you could do the same in reverse, by applying (say) 5 volts to the secondary for a few microseconds, then removing it in the same way, and then rectifying a high voltage out of the primary. You would need the electronics to pulse the secondary at the right frequency. The electronics are non-trivial, as you would be designing a switch mode power supply. If you want to try, maybe post a schematic of your concept here, and people can give feedback.
  10. Alec_t
    Sep 17, 2013
    5,971
    1,135
    I doubt they do. I used the word 'may' intentionally. I've never stripped down a switcher tranny to see if, for example, there is inter-layer insulation apart from the wire enamel. I was just pointing out a possible problem, since the tranny isn't designed to be used back-to-front.
    shortbus likes this.
  11. kyu9971
    Mar 28, 2015
    57
    My idea was to use the tl494 (most diffuse in pc power supply) and connect 2 transistor on pinout 9 and 10.with these transistors i will have driven 2 mosfet (maybe irf3205) and after the transformer.
    the central tap on +12vdc, the "sources" of mosfets to gnd and the drains to the other 2 tranformer pins.
    what do you think?
  12. crutschow
    Mar 14, 2008
    13,496
    3,373
    What is the purpose of this?
  13. Dodgydave
    Jun 22, 2012
    5,150
    769
    are you making an inverter 12 to 240v?
  14. kyu9971
    Mar 28, 2015
    57
    I would like, if possible,
    But now i am working on a circuit where there are two components that need of 220 vac for some seconds and max 11 watt.
    so the idea of to realize an little inverter 12 vdc - 220 vac And so I thought to the transformer of atx power supply.
    kyu9971
  15. Dodgydave
    Jun 22, 2012
    5,150
    769
    if your making a standard inverter, an atx transformer is no good as they work on 80 to 120 Khz, a standard mains inverter is designed for 50 to 60 hz.
  16. kyu9971
    Mar 28, 2015
    57
    I thought to set the first tl494 in order to have an frequency that you say (80/120 kHz) and then with a second TL494 I will drive the h bridge with frequency 50/60 hz As an inverter.
  17. ian field
    Oct 27, 2012
    4,447
    791
    A flyback transformer uses pulsed DC - Pre-ATX, quite a few PC PSUs were flyback topology.
  18. alfacliff
    Dec 13, 2013
    2,449
    428
    it would be much simper, since you will need a totally different core material for the lower frequency you want to output, to make an inverter from 12 volts to 220 volts directly. or an inverter running off rectified line voltage to drive the 220 vac output. thematerial of the atx transformer will not work with lower frequencies without a lot of loss.
  19. Roderick Young
    Member
    Feb 22, 2015
    408
    168
    alfacliff nailed it. A switching transformer will have too low an inductance to be driven at 50/60 Hz. It would be better to simply buy a 220 to 12 volt AC transformer, and wire it backwards.
  20. kyu9971
    Mar 28, 2015
    57
    Sorry, maybe I explained badly.
    I would drive the transformer ( ATX ) say 100 khz , and get a high voltage that will be rectified ' around 250/300 vdc . Then by means of a "H bridge" drive by a another TL494 , in this case made to oscillate at 50/60 hz , I obtained a sine modified waveform.
    I was inspired by an inverter repaired recently.
    kyu9971
