Hi all,
Hoping this would appear soon enough on the board as this is my first post here.
I have a Silverstone ST350 power supply. It was bought a few years ago(out of warranty now) and the machine was hardly used. I had issues starting that machine over time but after a few tries it worked. Then earlier in the summer it stopped working completely!
As I just don't like throwing out electronics unless they are really dead, I opened it up to see if anything can be done. There was never any burned electronics smell from it and even now it smells OK. I was looking for a fuse but couldn't find one except it is the one with a black sleeve on it. So I thought let me start from the beginning. I tested the switch continuity in both states and it turned out that the switch connects one wire of the ac supply but not the other (switch cuts both supply wires instead of only one).
Here are the details of the switch just in case: http://www.canal.com.tw/images/products/MR.htm
At this stage: I see two options(assuming the PS is fine otherwise):
The second option brings up the question for those experienced in SMPS ATX power supplies. What would I loose by connecting the second wire directly to the power plug (permanently or temporarily)?
My reasoning: The computers I have are usually powered ON and I rarely use the power switch. This is a Dell machine and the original PS didn't even have a ON/OFF switch.
Thanks for the suggestions in advance.
- Replace the switch
- Connect second wire directly without the switch
