ATX power supply safety
Discussion in 'General Electronics Chat' started by zeta_no, May 23, 2011.
  1. zeta_no
    Jan 20, 2009
    7
    I finished the conversion of an ATX power supply as a benchtop power supply. It works.
    Now I am concerned about the safety of such a device. Let say I take the 5V rail of my power supply. It is rated 5V, 29.0A.
    If I short this rail what will happen?
    My DMM gives 0.2 Ohm for the wire I would use to short. A quick calculation gives 25A and therefore 125W rushing in. To me, it looks like a good spark!
    Nobody seems to care on internet. Is there a safety mecanism in these ATX power supply that prevents large current rush? If so, what is it? Do all power supply implements it?
    Thank you,
    zeta_no
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One way to avoid allowing the magic smoke out of the supply is to fuse the outputs at a level below the maximum rating. Use 32 volt rated instantaneous fuses.
  3. Jaguarjoe
    Apr 7, 2010
    770
    90
    I used resetable Polyfuses.
  4. muthukumar_ece2004
    May 20, 2011
    9
    For Bench top power supply, 29A rating not necessary. Simply limit the output current of the SMPS and use it!
  5. magnet18
    Dec 22, 2010
    1,232
    125
    If you short an ATX power supply it will shut itself off, try it and see (be careful in case it doesn't for some reason)
    You might get a brief spark, nothing more.
    And whered you get a 29A supply!
    mines only 12 :(
    (not that I really have any use for 5V 29A...)
